H steering linkage ?
Posted by Two Bit on October 31, 2003 at 06:33:22 from (168.37.239.58):
What is the proper part name of the small u-joint that connects the shaft from the steering wheel to the shaft going to the front bolster (near the area under hood where gauges are)? Mine is all worn out and has lots of play. I have found parts online described as "steering knuckle pivot outer bearing race" and "steering knuckle pivot inner bearing race". Are these the parts, and if I buy the pair will these parts totally rebuild my bad u-joint or do I need additional parts?
Post A Followup
: Re: H steering linkage ?
