Re: Hydraulic and trans fluids H
Posted by williamf on November 01, 2003 at 01:48:29 from (66.82.9.31):
In Reply to: Hydraulic and trans fluids H posted by Sam F. on October 31, 2003 at 20:17:19:
The transmission and rear end both fill through the same hole, located on the right of the gear shift. ( 90wt. gear oil, according to the manual)
They have two drains, one under the pto, the other at the front of the transmission. They share a check plug, square head by the clutch pedal.
The hydraulics (30wt. non detergent motor oil) are separate, the reservior and pump are right behind the clutch. The fill is by the starter, the drain directly below that.
Wm
Post A Followup
: Re: Re: Hydraulic and trans fluids H
