Re: Super A Lift Setup
Posted by scotty on November 01, 2003 at 07:14:41 from (199.231.49.128):
In Reply to: Super A Lift Setup posted by Kevin (FL) on November 01, 2003 at 06:48:24:
Kevin,
That is the correct Super A setup with the rear rockshaft between the rear fenders. The Super A fenders are a heavier gage steel than a regular A to be able to withstand the weight of the various implements being lifted. Others on this site can tell you how much weight you can lift with this setup, Im thinking about 500 lbs.
scotty
Post A Followup
: Re: Re: Super A Lift Setup
