Re: '40 H brake replacement questions.
Posted by Michael Soldan on November 03, 2003 at 18:32:42 from (216.46.130.33):
In Reply to: '40 H brake replacement questions. posted by bill on November 03, 2003 at 15:28:07:
Bill I'm sitting here looking at the diagrams for H and M brakes along with the parts numbers. Removing the brake band lever should let the brake band lever shaft slide out of the brake pan, thus releasing your brake band. You can then remove the brake band connection pins and the band will be free of the shaft. The brake band levers have a brass bushing that inserts into the pan as well as one that inserts into the tractor. If these are worn you may as well replace them, Case I-H can still get them but they are pricey..$10 for a package of two. Good luck from Mike in Exeter Ontario
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
