Oil bath air filters
Posted by Joe on November 03, 2003 at 18:44:00 from (66.243.138.110):
On a B414 diesel, can the oil be sucked out of the oil bath air cleaner into the sump? I'm getting a little extra oil every time I run the tractor. Injectors are recently rebuilt, runs great, no smoke if I don't put much oil in the air cleaner. Injector pump rear seal doesn't seem to be leaking, but the pipe that runs from the intake maniford to the gear plate on the injector pump is running with oil. Interesting, but puzzling. Any thoughts?
Post A Followup
: Re: Oil bath air filters
