Farmall Tractors Discussion Board
Re: Cleaning Oil - F20
Posted by Milan on October 01, 1999 at 06:51:01 from (209.69.206.184):
In Reply to: Cleaning Oil - F20 posted by Dan on October 01, 1999 at 06:24:17:
The clear stuff was water, most likely condensation, unless there was alot, then most likely rain water that found it's way down the exaust stack.
For a flush use kerosene, if the sludge is really bad, add 1 quart of kerosene to your oil and run the engine for 10 minutes, then drain while still hot.
Or remove the oil pan and give it a bath. And use a pump sprayer of kerosene, or a spray can of Gunk degreaser. After washing, give everything a liberal bath in WD-40..or something similar.
Post a Followup
: Re: Re: Cleaning Oil - F20
