Re: M, with M W hand clutch
Posted by Stan(VA). on November 07, 2003 at 05:47:58 from (208.59.156.217):
In Reply to: M, with M W hand clutch posted by Marc on November 06, 2003 at 19:41:20:
If it's just slipping because of to little pressure, you can remove the small side cover and there is a large nut facing you that should be tightened to require ~30-40lbs of hand pressure to pull or push the lever. The nut will have a locking tab on it also. If it's not that, next likely problem could be the fibre discs getting their teeth chewed off. If so, they will need to be replaced. Email me for a link to a parts breakdown if interested.
Stan(VA).
Post A Followup
: Re: Re: M, with M W hand clutch
