Re: Re: wheel size on an F-12
Posted by Zak on November 08, 2003 at 06:29:02 from (205.188.209.82):
In Reply to: Re: wheel size on an F-12 posted by Nebraska Cowman on November 08, 2003 at 03:46:25:
Depends really. Fronts are 4.00x15's or 5.00x15's (I have 4.00's). Rears can be the expensive 40 inchers as stated, or you might have a set of H rims on it, in which case you can use 11x38's. If this is the case, you might be able to locate a set of irrigation tower tires which are less expensive than actual tractor tires, but no less effective for what we tend to use our tractors for. Zak
Post A Followup
: Re: Re: Re: wheel size on an F-12
