Re: Re: Farmall C Dripping carbutor
Posted by Scotty on November 09, 2003 at 03:59:49 from (216.231.136.109):
In Reply to: Re: Farmall C Dripping carbutor posted by Wayne Swenson on November 08, 2003 at 19:31:14:
THANKS FOR THE INFO. I HAVE PUT A IN-LINE FILTER ON AND HAVE HAD THE CARB. APART TO CLEAN THE TRASH OUT AND TO PLAY WITH THE FLOAT LEVEL SO MUCH THAT I AM WEARING THE SCREWS OUT TAKEN THIS THING APART SO MUCH. I AM DETERMINE TO FIX THE THING CAUSE IT DOESN'T LOOK LIKE ANY ROCKET SCINECE BUT APPARENTLY I AIN'T GOT THE BRAIN POWER TO FIGURE IT OUT, SO ANY HELP YOU CAN GIVE ME I DO THANK YOU. THE FLOAT DOESN'T SEEM TO BE HITTING THE BOWL. THE BOWL HAS A DRAIN PLUG IN THE FRONT OF IT, DOES IT SUPPOSE TO HAVE A PLUG OR A ADJUSTABLE HIGH SPEED VALUE IN PLACE OF THE PLUG. I THINK THIS VALUE COULD CONTROL THE FUEL FLOW TO THE BOWL. DOES THIS SOUND LIKE IT COULD BE A PROBLEM ? THANKS FOR YOUR TIME...
SCOTTY
Post A Followup
: Re: Re: Re: Farmall C Dripping carbutor
