Re: CUB vs JD LA vs MH PONY
Posted by jocco on November 09, 2003 at 13:50:38 from (65.223.228.54):
In Reply to: CUB vs JD LA vs MH PONY posted by Small Battle on November 09, 2003 at 09:05:50:
la hands down will out pull out work: yes no hydralic but li did have and a pto is optional. And yes much more stylish, comfort would go to the mh or cub. You for got the allis chalmers g it will hold its own with the la (same engine as pony). A massey harris pacer might have the advantage on engine power.
Post A Followup
: Re: Re: CUB vs JD LA vs MH PONY
