Farmall Tractors Discussion Board
Re: Cleaning Oil - F20
Posted by Louis G on October 01, 1999 at 22:09:20 from (207.19.4.152):
In Reply to: Cleaning Oil - F20 posted by Dan on October 01, 1999 at 06:24:17:
Dan, you can safely flush the sludge from your engine without removing the pan. The product to use is Justice Brothers Oil System Cleaner - this will desolve the sludge and you can drain it out with the oil. The JB Oil System Cleaner contains chemicals that enhance the lubricating properties of the oil;thereby, giving you extra protection from poor lubrication and the possibility of turning a bearing or other damage - which is very possible with kerosene. Just be sure you don't try to clean a gallon of sludge from the engine with one flush as the oil system is not designed to handle that much crud at one time.
Post a Followup
: Re: Re: Cleaning Oil - F20
