Broke high low reverse cam pivot shaft arm on Far
Posted by David on November 09, 2003 at 17:29:40 from (208.137.151.203):
I have an 806 International Farmall tractor. 1965 year model, I think. My high low and reverse cam pivot shaft arm broke off and I must replace it. What are things to be careful of when removing the top cover that has the shifter and oil filler on? The arm sheered off even with top plate. Also, where can this part be ordered and approximate cost?
Post A Followup
: Re: Broke high low reverse cam pivot shaft arm on Far
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
