Re: m hydraulics
Posted by Aces on November 12, 2003 at 10:18:42 from (67.0.36.160):
In Reply to: m hydraulics posted by allen on November 12, 2003 at 09:15:00:
Allen use one of the pressure ports from the belly pump and go to the in port on a two way valve and from the out or tank port back to the belly pump fill or drain plug. when you want to use the 2 way lock the belly lever back for raise then use the 2 way, if you want to use the belly pump lock the 2 way one way or other.
Post A Followup
: Re: Re: m hydraulics
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
