Re: removing stuck wheel weight bolts
Posted by rustyfarmall on November 13, 2003 at 13:56:43 from (216.248.75.146):
In Reply to: removing stuck wheel weight bolts posted by joe on November 13, 2003 at 11:28:51:
I doubt very much if the paint has anything to do with it. Those bolts are more than likely rusted solid, you will need either an air impact, or an oxy-acetylene torch, and heat the area around the bolt, you won't hurt the cast-iron wheel any. I encountered the same thing a few years ago, I thought penetrating oil and patience would solve the problem, but after about 3 weeks, I ran out of patience, and went for the torch. Problem solved.
Post A Followup
: Re: Re: removing stuck wheel weight bolts
