Re: Grade of Gas needed
Posted by Bob on November 16, 2003 at 16:42:32 from (66.163.134.177):
In Reply to: Grade of Gas needed posted by Gramps544 on November 16, 2003 at 16:34:16:
Have you noticed "pinging" or detonation with 87 octane?
As far as ethanol is concerned, while they may be some issues of the ethanol dislodging crud in the fuel system and plugging things up, usually gas with ethanol is HIGHER octane than standard unleaded.
Post A Followup
: Re: Re: Grade of Gas needed
