Re: Super M reservoir and live hydraulic pump for
Posted by Stan(VA). on November 18, 2003 at 10:37:49 from (65.88.96.229):
In Reply to: Super M reservoir and live hydraulic pump for M posted by MMay on November 17, 2003 at 20:26:44:
The only benefit I can think of is that the hyd level is always above the pump with the under tank reservoir, so I would think that system would be easier to keep primed than the reservoir in the belly pump, but I know those work too. And I don't see why you couldn't series the two together to get more capacity, I'd run the outlet from the under tank reservoir to the fill for the belly pump, and then take a line from the drain under the belly pump as your return to the pump. You might want to dril and tap a larger hole for that return though as I think they are typically a 1" diameter hose and the drain woln't be that big. I get away with an aftermarket (ie:cross/prince) 2 spool valve, 1 spool for 3 pnt, 2nd with quick connect couplers for remote or loader bucket, they I use the factory 1 way valve in the reservoir for the main lift cylinders on the loader (lift only). That works if you don't mind the controls being in different places which is fine for hobby use, but would be terrible on a machine you worked full time. That said, I'd recommend you get a 3 or 4 spool open center valve and mount it convienient to you (like on the seat box). Two spools could operate the loader, one for the 3 pnt and optionally a 4th for a remote connection out back. Run it in series with the pump and reservoir. ie: take the pressure line from the pump to the inlet on the valve, outlet from valve to the inlet on the reservoir. One exception would be if you are adding PS for the loader. Then you would need a priority flow divider between the pump and the valve inlet, with the PS return going to the reservoir. Stan(VA).
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
