Re: removing rear wheel
Posted by Michael Soldan on November 19, 2003 at 15:14:37 from (216.46.130.8):
In Reply to: removing rear wheel posted by Jim on November 19, 2003 at 12:24:38:
Jim, I do something like Old suggested,doing Farmall H's. I block the drawbar support structure so that it could hold the weight of the tractor then I leave the jack in place. I usually use two jack stands under the drawbar frame. I've had some real fun getting rear wheels off. had to put a hydraulic jack between the rear housing and the axle clamp even when I had the bolts out of it...be carefull and good luck ...Mike in Exeter Ontario
Post A Followup
: Re: Re: removing rear wheel
