Re: Re: Re: C-113 C123 -- Change out??
Posted by Stan(VA). on November 20, 2003 at 13:00:24 from (206.71.102.144):
In Reply to: Re: Re: C-113 C123 -- Change out?? posted by JIM on November 20, 2003 at 08:39:34:
Jim,
You should be able to use a block out of a C/Super C/200/230/Super A/Super A1/100/130 (not saying they're all the same but you can use them). The C123's in the 140/240 are cast different in the front of the block for the new style water pump and the front pulleys bolt on and use the narrower belt. The C113's in the A/B's would fit but have no hyd pump cutout like was mentioned and you would need a longer bolt and nut for the front bolster where the pump should be.
Stan(VA).
Post A Followup
: Re: Re: Re: Re: C-113 C123 -- Change out??
