424,454,464,2400,2500 hydraulic question
Posted by kirk on November 20, 2003 at 16:17:08 from (67.243.42.43):
Help! The hydraulics on my 2400a make a loud high-pitched squeeling noise that seems to change pitch when the steering wheel is turned. After about 30min of running the hydraulics over-heat and the unloader valve sticks leaving the 3 point lift stuck in the up position. Everything works fine until it gets too hot. The Wet brakes had wore out and put a lot of grindings in the oil. I've replaced the brakes, oil, and filter a few times until it looked clean. Any body had a problem like this? Thanks in advance.
Post A Followup
: Re: 424,454,464,2400,2500 hydraulic question
