Setting the Points Engine Timing
Posted by Allan on November 23, 2003 at 12:54:01 from (148.63.132.164):
Hi Guys, I read a post this morning about point setting and timing which was somewhat misleading, so thought I'd pass along these thoughts: As you undoubtedly already know, each degree of dwell angle change at the points will make a direct and corresponding change to engine timing at a rate of roughly 3 degrees engine timing to 1 degree of dwell (depending on the engine design). Conversely however, engine timing cannot change dwell angle. This is why the method of ‘wiggling it ‘till it sounds better’ timing setting seems to work to your ear, but is also very seldom correct in it’s relationship to the actual stroke of the engine. Therefore, it is not a bad idea to just 'take a peek' at the timing (preferably just “after” setting the points) to make sure the last guy who timed the engine had his dwell angle set correctly when he timed the engine. Also, it is a good idea to set the dwell on the low side of the spec (wider gap). This is because as the fiber on the point arm wears, the points are always moving (wearing) closer together (increasing the dwell angle). The practice of setting the dwell angle low to start with, will cause the wear effect of the points’ fiber rubbing surface to move the points themselves ever closer or "towards" the "correct" setting, then past that correct setting and into the high side of the spec, as the wearing proceeds. Bottom line: a longer period of time in which the points are in correct adjustment. Another neat trick is to time the engine using a timing light hooked to the coil wire instead of the #1 plug wire. Try it; you’ll like it. Just some ideas, Allan
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
