Re: Starting problem on Farmall M
Posted by Wayne Swenson on November 23, 2003 at 21:04:38 from (66.228.234.68):
In Reply to: Starting problem on Farmall M posted by Kevin on November 23, 2003 at 20:51:09:
If the cables are hot, you have cranked too long (30 seconds max) or have a bad connection somewhere. The tuneup specs are found in the "Tune-up Specs" link on the left side of this page. Next attempt determine what is not happening: 1. is there spark at the right time? Make sure the wires in the distributor are not accidentally grounded. 2. is the compression decent? Squirt some oil in each cylinder to regain what has disappeared with your starting attempts. 3. is there a fresh fuel supply (less than a month old) getting to the cylinders? Remove the spark plugs & put a teaspoon of gas in each cylinder, replace the plugs , turn on the switch, and try cranking. The 12 volt system is negative grounded and the coil negative terminal should be attached to the points terminal. Take your time, check out each component like you were Sherlock Holmes and you should have a running "M" soon.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
