Re: IH 340 runs worse after tune up
Posted by Gramps544 on November 24, 2003 at 12:02:29 from (65.178.129.140):
In Reply to: IH 340 runs worse after tune up posted by Sean Johnson on November 24, 2003 at 11:41:51:
Well, you eliminated the possiblity of a cylinder not firing. I am assuming you set the dwell correctly on the points. The fact that it runs worse now with all the old parts is odd.
I would check the dwell, top of the dist. cap (for a crack), the gap on your new plug. If that all appears to be ok, try putting in the old plugs.
Post A Followup
: Re: Re: IH 340 runs worse after tune up
