IH 340 runs worse after tune up
Posted by Sean Johnson on November 24, 2003 at 11:41:51 from (24.51.83.7):
Just tuned up my International 340 and now it runs worse (rough) than it did before. I replaced the distributor cap, plugs, rotor, and points. I then substituted the original parts one by one (except the plugs) and there was no improvement. (thought maybe one of the new parts were defective) I used a plug tester to check each of the 4 plugs and the light seemed to flash the way it supposed to. The plug wires are in decent shape but I substituted a temp wire one by one.
I feel pretty silly spending $70 and have it run worse. Any help would be most appreciated.
Thanks,
Sean Johnson
Post A Followup
: Re: IH 340 runs worse after tune up
