Re: IH 340 runs worse after tune up
Posted by Ben in KY on November 24, 2003 at 13:33:07 from (192.76.82.90):
In Reply to: IH 340 runs worse after tune up posted by Sean Johnson on November 24, 2003 at 11:41:51:
Are you sure that the dist to plug wiring is all in proper order ? Been there done that, was embarassing.
Post A Followup
: Re: Re: IH 340 runs worse after tune up
