Re: Help: Rebuilt head / new valves, 1949' C
Posted by Randy in NE on November 26, 2003 at 04:23:32 from (216.58.237.20):
In Reply to: Help: Rebuilt head / new valves, 1949' C posted by Josh on November 25, 2003 at 19:00:57:
Make sure you have the correct head gasket. My '50 C had 3 1/8" instead of the 3" pistons. Had trouble finding the correct gastket to match up with the water ports. Most of the 3 1/8" head gaskets assume you have a water pump so the water port holes are smaller. Ended up drilling them out to get better cooling flow. I used a high temp silicon and put a light coat on both sides of the gasket. If you check the archives others spray on a couple of coats of sealer. Be sure to start your torque sequence from the center and work out. I started torquing at 40 ft-lbs and worked my way up to 80 ft-lbs going in 10 lb increments. After you have run it for a while you will want to remove the valve cover and rocker arms and re-torque the head. This means resetting the valves. No big deal. The manifold is torqued to 20 flt-lbs. Valves are set to 0.014"
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
