Re: Re: Re: Re: Re: Re: Low Oil Pressure in Super
Posted by Stan(VA). on November 26, 2003 at 08:22:10 from (206.71.102.144):
In Reply to: Re: Re: Re: Re: Re: Low Oil Pressure in Super A - posted by Buster on November 26, 2003 at 08:00:10:
Between the bottom plate and the pump housing. Look carefully at the edges and see if there is any small pieces of gasket material sticking out. There usually is.
Stan(VA).
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Low Oil Pressure in Super
