Will a 460 PTO bolt up to a 400?
Posted by Male Gayle on November 28, 2003 at 16:16:53 from (209.166.66.157):
I recently bought a gas 400 in good shape that is missing the PTO. It was removed to reduce weight for pulling. I have access to a diesel 460. Will the PTO from the 460 bolt up to a 400 without modification? Thanks for any info you can give me.
Post A Followup
: Re: Will a 460 PTO bolt up to a 400?
