Re: international b275 timing
Posted by Joe on November 29, 2003 at 12:10:33 from (66.243.138.28):
In Reply to: international b275 timing posted by jack in acton ca on November 29, 2003 at 10:30:59:
Ok, hope this helps. My I&T service manual says that the optimum timing is 20 degrees BTDC. Although 20 is optimum, timing can be retarded as far as 16 degrees BTDC in cases where engine noise is critical and power requirements are not exacting. However, timing should not be advanced more than 22 degrees BTDC or max power will be reduced and glowplug failure will be increased. Hmmm. You can check the pump timing as follows: 1. Shut off the fuel and remove the injection pump timing window and clutch housing dust cover. 2. Turn engine in direction of normal rotation until the No. 1 piston is coming up on the compression stroke. Continue turning until the "TDC" mark on the flywheel aligns with the scribe mark located on the left front flange of the clutch housing. 3. Check the timing marks on the engine front end plate and pump mounting flange. 4. If alignment is required, loosen nuts on pump mounting studs, align the mark on pump mounting flange midway between the two marks on the engine front end plate and retighten the nuts. At this time, the "E" scribed line on injector pump rotor should align the scribed lines at the lower hole of the pump snap ring. These marks are visible after removing a small cover panel at the main drive gear. 5. Note: Movement of the pump between the two scribed lines on the engine front end plate gives a variation of about 3 degrees. Man! Got a finger cramp.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
