Farmall Tractors Discussion Board
Re: Help needed with carburetor adjustment for Farmall M (1944)
Posted by Rich Cota on October 05, 1999 at 05:15:37 from (198.56.12.229):
In Reply to: Help needed with carburetor adjustment for Farmall M (1944) posted by Rod H on October 04, 1999 at 20:34:54:
Turn in the air adjustment screw (near the top of the carb and at a angle to the carb) all the way and then back it out 1 1/2 turns. Turn in gas adjustment screw (near the bottom of the carb and in front of it) all the way and then back it out 2 3/4 turns. The other screw (near the top front and at a 90 degree angle to the tractor) is the idle speed adjustment. Set it for the idle speed you want. Screw in to increase speed.
Post a Followup
: Re: Re: Help needed with carburetor adjustment for Farmall M (1944)
