Re: light problems for 12 volt conversion
Posted by Bob M on December 03, 2003 at 12:49:40 from (165.170.128.65):
In Reply to: light problems for 12 volt conversion posted by Buster on December 03, 2003 at 12:27:43:
Buster - Use a #168 lamp instead. Any parts place will stock that (or you can pull one out of the side marker or dashboard in your car...) Also an 1815 and 1816 lamp will work.
An 1157 will likely NOT work! Resistance is too low - will make the alterator back feed the ignition coil and make it difficult to shut off the engine.
Post A Followup
: Re: Re: light problems for 12 volt conversion
