560 hydraulics screeching noise
Posted by joe on December 04, 2003 at 06:14:21 from (205.146.39.81):
The hydraulics appear to be under maximum load. There is no hydraulic hitch, but when I connect a short hose in a loop between 2 remote outlets and pull the lever associated with those outlets to allow fluid to flow in the loop, the noise lessens substantially and the engine unloads. Could this be a pressure valve stuck? If so, where would I look? and is it something easily fixed? The hydraulic filter was badly plugged. Could this have caused it? I can't test it now because the tractor is split for complete overhaul, etc. The power steering also did not work.
Post A Followup
: Re: 560 hydraulics screeching noise
