Re: Farmall H LP??
Posted by Nebraska Cowman on December 04, 2003 at 17:03:04 from (65.165.16.225):
In Reply to: Farmall H LP?? posted by Farmall Daddy on December 04, 2003 at 16:38:02:
Propane makes a little less horsepower but if you increase compression it pretty well compensates. I have an lp set-up for an H. The tank has a hole through it for the steering shaft.
Post A Followup
: Re: Re: Farmall H LP??
