Re: cold weather starting...tricks?? HELP!!
Posted by Red Dave on December 05, 2003 at 11:14:16 from (24.104.94.34):
In Reply to: cold weather starting...tricks?? HELP!! posted by Josh in Maine on December 05, 2003 at 10:56:27:
Try what gene b says below and also make sure every connection is clean, tight & bright. Including the ground side too. Also make sure the engines are tuned up good too.
My '40 B pops right off in any weather year-round with the same set up you have (magneto & 6 volt starter), but I know I don't see as much cold as you do in Maine.
Post A Followup
: Re: Re: cold weather starting...tricks?? HELP!!
