Re: cold weather starting...tricks?? HELP!!
Posted by Hugh MacKay on December 05, 2003 at 13:25:38 from (209.226.247.82):
In Reply to: cold weather starting...tricks?? HELP!! posted by Josh in Maine on December 05, 2003 at 10:56:27:
Josh: Follow what these guys have said, partcularly with the cables and connections. I was raised just a couple hundred miles to the Northeast of you in Nova Scotia. I have started 6 volt farmalls unassisted by any devices at -40. Yes it makes you wish they didn't start. Another item I find improves the C-113 and C-123 engines is a new type starter drive my IH partsman calls a clutch drive. They are much smoother than the old bendix.
These tractors have seen a lot of years now and just maybe carb kits are in order.
Post A Followup
: Re: Re: cold weather starting...tricks?? HELP!!
