Re: cold weather starting...tricks?? HELP!!
Posted by mbnok on December 05, 2003 at 15:25:07 from (216.226.31.24):
In Reply to: cold weather starting...tricks?? HELP!! posted by Josh in Maine on December 05, 2003 at 10:56:27:
Set throttle 1/4 to 1/3, choke full, lift twice, choke to half, ____switch on, goood yank on crank or hit the starter it will go. Ignition must have blue spark and needle valve not letting engine flood. Most times I had trouble I got the engine flooded. then you have to set the throttle lower, choke off, to clear the flood. this works on all (B C H 674) my 400 is diferent. Now keep in mind it doesn't get to -40 in my part of Okla.
I hope.
Post A Followup
: Re: Re: cold weather starting...tricks?? HELP!!
