Re: Re: cold weather starting...tricks?? HELP!!
Posted by Jonathan Mirgon on December 05, 2003 at 18:47:09 from (205.208.129.97):
In Reply to: Re: cold weather starting...tricks?? HELP!! posted by gene b on December 05, 2003 at 11:07:25:
I have a 1940 (a) that I have rebuilt. The head has been planed,new valves springs,hardened seats installed, new liners, pistons, rings, rod and main bearings.Mine is distributor ignition.I am in Ohio and so far mine has popped off at 20 degrees with no problem on 6 volts. Good compression, ignition timing, carberator, and good tight electrical connections are the key to starting these old beasts in cold weather on 6volts. If your tractors have never been overhauled things are probably hampered enough to cause them to start hard in cold weather. maybe a 12 volt conversion would work good for you.
Post A Followup
: Re: Re: Re: cold weather starting...tricks?? HELP!!
