Re: fluid damaged rims
Posted by 42FarmallH on December 06, 2003 at 18:45:34 from (12.15.56.64):
In Reply to: fluid damaged rims posted by paul on December 06, 2003 at 18:35:41:
Well, you will find out when you take the tires off. I managed to repair a rim on my H that was just bad around the valve stem hole - although the inside was still rough and required a liner to be used.
Best idea is to JB weld or weld a plate over entire bad area (grind away or cut rust away first) and drill a hole somewhere else on the rim. Just my $0.02 worth...
Post A Followup
: Re: Re: fluid damaged rims
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
