Re: B magneto
Posted by terry on December 07, 2003 at 08:15:07 from (67.250.216.7):
In Reply to: B magneto posted by Matt on December 07, 2003 at 02:08:51:
If coil is out of mag, I can't help you.
If its in the magneto, spin the drive wheel the direction of resistance. I usually use an adjust-able wrench cause turning it by hand is almost
impossible. With a wire coming out of the coil, hold it about a quarter inch from the mag and see if the spark makes the trip. Spark should be easy to see and the bluer, the better.
I usually wrap the mag with a rag and put it in a vice.
Hope this helps.
Post A Followup
: Re: Re: B magneto
