Shimming a lift all pump
Posted by Tim Mc on December 07, 2003 at 09:20:16 from (64.235.213.81):
The lift all pump in my H puts out 800psi pressure at idle my manual says 800psi is the propper preasure for the lift all pump but it is insuffiecent to run serveral implements that i have (wood splitter needs about 1200psi)
I plan on removing the pump and machining up some shims for the preasure relefe/kickoff valve.
Has anyone ever done this??
I dont see any problem in doing this, please post your thoughts.
Post A Followup
: Re: Shimming a lift all pump
