Re: Transmission fluid????
Posted by Tim on December 07, 2003 at 10:42:49 from (64.235.213.81):
In Reply to: Transmission fluid???? posted by Griz on December 07, 2003 at 09:35:45:
Some (or most) of the seals in the transmission case on your h will most likely need to be replaced, i had to replace every seal on my H when i got it.
The problem is that over the years the old leather/felt type seals dry out and leak, its very common, the transmission takes 6 gallons of 85-140, you may also get some luck with the leaks by adding a few liters of automatic transmission fluid, for some reason ATF seems to make the old leather seals swell up and it might stop leaking.
Post A Followup
: Re: Re: Transmission fluid????
