856 Brake Leaking.
Posted by BFarr on December 07, 2003 at 18:46:20 from (64.91.167.168):
Well the snow is almost moved, but I have a leaking brake on left side that I assume to be o-rings.
I have the parts manual and I am currently trying to locate a repair manual..but would like to repair asap.
Is this a straight process.. remove the drum cover and remove a brake pack as a unit to replace o-rings??
Can anyone help.
Thanks
Post A Followup
: Re: 856 Brake Leaking.
