Re: Transmission fluid????
Posted by Michael Soldan on December 07, 2003 at 18:53:58 from (216.46.130.12):
In Reply to: Transmission fluid???? posted by Griz on December 07, 2003 at 09:35:45:
Griz this is quite common that an old Farmall will have leaked down and when you fill it to the proper level you think you have new leaks when in fact they are old ones. It is most likely one of two seals up under the belly pan where the lift all is located( or not..if you don't have a lift all the job just got easier) There are two seals off of the rear housing , one on the drive shaft and one on the lift all shaft. Undo the bolts on the drive shaft and lower it out of the way,using a pipe wrench undo the collar and the seal will be accessable( Both shafts have a collar) Your Case-I-H dealer still handles replacement seals which are about half the width of the original. Pick the old seals out and replace, then refill your rear end with gear oil. My one H was leaking only on the liftall shaft and I did the PTO shaft as well, my other H needed axle seals and PTO ..not an impossible job but will eat up a Saturday As is pointed out be carefull if you need to do axle seals.Block the tractor up good , getting the wheels off the axle is a toughie, I've done it alone but it would be better if a friend was there, clean the axle and rub it smooth and shiny with emery cloth,udo the housing bolts and pull the axle seal housing off, grease the axle up and slde the new seal in housing back on and rebolt..it took me about three hours to get the wheels off and a half hour to change the seals, then you have fresh rear gear oil and no leaks...good luck ding me if you need help...Mike in exeter Ontario
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
