Farmall A throw out bearing
Posted by Hilltopper on December 07, 2003 at 19:37:03 from (65.178.178.153):
I was wanting to replace the graphite throw out bearing on my A. I went to the IH dealer and he could not find it upon his computor. It showed a carrier with a ball bearing, but no graphite bearing.The change over would cost about $150. Does any one know the No. of the origonal bearing? Thanks.
Post A Followup
: Re: Farmall A throw out bearing
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
