Re: Farmall A throw out bearing
Posted by Haas on December 08, 2003 at 14:15:03 from (12.65.43.143):
In Reply to: Farmall A throw out bearing posted by Hilltopper on December 07, 2003 at 19:37:03:
Another way to go is to find a used carrier, or buy a new one from IH. Then go to a clutch shop or bearing house and buy the bearing there. When I redid my clutch, the clutch shop that did the rebuild had the bearing. Mine already had the carrier for the ball bearing.
Post A Followup
: Re: Re: Farmall A throw out bearing
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
