460 utility oil levels
Posted by petenev on March 31, 2009 at 10:52:06 from (207.200.116.5):
Hi Guys Can someone tell me how to check and where to fill the hyd oil, also the differential and trans. Also on the fast hitch when it is in the down position it still has 4 or 5 inches of rod out is there a way to adjust that so the hitch goes down farther? Thanks Pete
