Re: 460 utility oil levels
Posted by Butch WI on March 31, 2009 at 16:52:07 from (96.13.219.90):
In Reply to: 460 utility oil levels posted by petenev on March 31, 2009 at 10:52:06:
Pete,
On my 460 U the hyd oil fill plug is next to the shift lever. It is approx. 1 1/2" plug with a sqaure indented in to it where I put a 3/4" drive rachet into to get it open. The level fill line is indicated by removing a plug on the side of the trans housing under your left foot running board. Take that plug out and fill with hy-tran until it runs out then replace the plug. On mine I add 5 gals more of hy-tran after it hits the plug level. As for the "rod sticking out" I'm not sure what you mean When my fast hitch is all the way down I cant really tell how much "rod" is left in the cylinder...if that is what you mean by rod.
Butch
