Re: Re: M.D Throttle problem
Posted by Farmaller on December 09, 2003 at 17:27:15 from (205.188.209.82):
In Reply to: Re: M.D Throttle problem posted by Haas on December 09, 2003 at 14:22:52:
Unhook the linkage at the pump with tractor running and pull back on pump lever. If you get more out of it,you need to adjust linkage to the pump. If not then you can adjust it inside the pump, but if this tractor has an old tired engine I wouldn,t run it that hard anyway.
Post A Followup
: Re: Re: Re: M.D Throttle problem
