Re: 1949 FARMALL M NOT STARTING
Posted by Chuck's Repair on December 11, 2003 at 15:01:49 from (216.170.58.10):
In Reply to: 1949 FARMALL M NOT STARTING posted by Mark on December 11, 2003 at 05:21:12:
Did you turn the engine over with the rotor gear reduction removed? If you did there is a very good chance the magneto is now 180 degrees out of time.A good indicator is if it backfires through the air cleaner while you are cranking it.
Post A Followup
: Re: Re: 1949 FARMALL M NOT STARTING
