Re: Re: Re: Re: Re: What is TA
Posted by John In Iowa on December 11, 2003 at 20:09:58 from (199.108.164.25):
In Reply to: Re: Re: Re: Re: What is TA posted by Hugh MacKay on December 11, 2003 at 16:59:08:
Hugh,
One of the hardest things on the TA was shutting down the tractor with the TA in the high side. If you ever had one apart you would see that if the engine turns backwards, such as dieseling when shutting down, with the TA in the high side everything locks up, sending a terrible shock through the TA with the overriding Clutch taking it the worst, causing flat spots on the ramps and rolling which lead to the clutch not locking up the go in the low side. If you shut in down with the TA in the low side everything with turn free to the transmission.
John In Iowa
Post A Followup
: Re: Re: Re: Re: Re: Re: What is TA
