Re: Re: Re: 434 differential lock problems
Posted by JB on December 13, 2003 at 08:11:27 from (24.157.143.220):
In Reply to: Re: Re: 434 differential lock problems posted by Ben in KY on December 12, 2003 at 10:30:11:
Hi, had a B414 and 434D many years ago that did the same thing with the diff lock. Sometimes would have to reach down and pull foot pedal up by hand and then touch left or right brake to make it release.
We later had a 384D and IH had put a return spring on the Diff lock pedal. Now the pedal would return but still had to touch brake to release. If all else fails push in the clutch.
I would not worry about braking an axle as I only know of one broken axle on a 434D and that was the operators fault. There were several B414, 434, 444, 384s around our area.
Always be careful with diff lock engaged as tractor goes in a straight line only. Also if both rear wheels are spinning the rear end can shoot left or right very quickly.
JB
Post A Followup
: Re: Re: Re: Re: 434 differential lock problems
